- colliehaulerExplorer III
DianneOK wrote:
I switched to oil filled heaters as well.
We also use an oil filled heater....works great - Free_Range_HumaExplorerRead the Amazon reviews for the AM05. The top-rated favorable review and the top-rated unfavorable review contradict each other.
- daytraderExplorer IIHas anyone looked in the Dyson Hot and Cool air multiplier? was thinking of getting that one (cost aside, I know they are pricey, but with airmiles don't matter.) Anyone had experience with them?
- mmiilleExplorerWe have the Duraflame. It heats uniformly also. You need a 15 amp receptacle though. It goes up to 12 amps and it will keep you warm. We bought ours at the local Fleet & Farm store for about $150. The stores start reducing their prices this time of year and you may find one cheaper.
Consumer Reports rates it high and I agree.
http://www.amazon.com/Duraflame-Williams-Portable-Heater-10HM4126-O107/dp/B004ALSJ4E - Carolina_CruiseExplorerWe tried several different heaters and some were ok and some were not. I found this Warming mat and thought I would give it a shot. It is great. It heats your space and pulls around 100 watts. I put it on the floor in front of the recliner and it keeps the area warm. Of course I don't get to use it since the DW tried it. It says not to use on carpet or hardwoods for fear of fading but we have not had an issue. The instructions say lay it on a piece of cardboard if you are worried about that. If you are paying the electric bill, these are 87% cheaper to run than the space heaters. They make two sizes and the first one we got was the small one. May try the larger one when I order another. I may get another small one to put in the bathroom. just my 02
- Paw_Paw_JohnExplorerI too looked for a better heating system, I found the cheap heat system. Look at it at rvcomfortsystems.com. I installed my cheap heat system into my gas heating unit and love it!!, I installed the 5000 watt unit because my camper has the 50 amp service and this system runs on 240 volts. I been using this system for over three years now and never had any problems. I own a 36 foot Mobile suite and keep it plugged into service all the time when it's parked at my house. I keep the heater set at 50 degrees all winter when I'm not camping in it. This system keeps my camper evenly heated and also heats the underbelly. Good luck,
- mikeleblanc413Explorer
Free Range Human wrote:
rockhillmanor wrote:
mikeleblanc413 wrote:
RE: 2000 Winnebago Minnie Winnie, 30 ft., no slide, 30 AMP
I am currently using a Lasko ceramic tower heater and want to know if there is a better option and can I make two heaters work? THANKS!
I have spent 100's of dollars and tried them ALL!
After 6 years on the road trying all the different heaters, you have the one that I have finally settled on. IMHO, it's the best.
I just saved you a $100!
What model of Lasko ceramic tower heater? Amazon has 12 Lasko ceramic tower heaters.
Sorry for the delay in responding. The Lasko Ceramic Tower I'm using is model #751320 and is 23 inches tall. - John___AngelaExplorerIf you are considering a little more permanent type setup you can also consider low wattage baseboard heaters. These are 500 watts, thermostat, mounted (no falling over) and kinda blend in. No fan so no noise but you will need 3 or 4 to make the heat even. We went this approach as well as underfloor heating (under laminate) which makes it easy on the feet. One of the posters on here (Piano Tuner) uses an after market heated carpet approach which he really likes. I guess my point is there are alternatives to the little heaters with fans. Good luck in your search and happy trails.
- nomad_289Explorer
Boldtining wrote:
Through the years rving, we've tried several electric heaters and have found the "Vornado" to work best at heating the rv. No doubt is because of the way it circulates the warm air about the space. Won't use any other method now.
X2.
Why it's Best:
1. Fan speed and heat automatically adjusts up/down to maintain thermostat temp.
2. Fan ensures uniform heat distribution in RV, ~no cold spots like with a radiant heater.
3. Fan is quiet, and even quieter when it slows down.
4. Small size.
5. 750W and 1500W settings.
6. Very accurate thermostat.
Theoretically I prefer a Radiant heater with no moving parts; but in sub-freezing temperatures I couldn't keep a uniform temp. A single Vornado solved that. Ideal might be a Radiant + Vornado.
AVH2
VH103
Make sure you get a Non-Digital model so you don't have to reset the temperature every time power is interrupted. - Free_Range_HumaExplorer
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
