Hi all, I am going to ask a very loaded question here but am looking for generalities. I have a 39' 5th wheel with 2 A/C Units. The place where we use it at has the electricity included in the pr...
Generally you should plan on $2-$4 per day. A/C usage or usage of multiple electric space heaters will put you on the high side and staying in locations with moderate temperatures where this usage is limited or not required will bring your cost to the low side. You will balance that cost out by not having to spend money for propane heat or propane water heaters so the numbers can be a bit fluid depending upon your coach setup and your specific needs.
