mchero
Nov 17, 2016Explorer
Furnace usage
Out here in Quartzsite AZ and had to fire up the furnace for the 1st time. I want to install an extend-a-stay type connection so I can use a larger tank but DON'T want to use the furnaces due to them ...
2gypsies wrote:
We used the Empire propane heater for 16 full-timing years with lots of boondocking (Quartzsite, too) - and even if we were plugged into electric at a RV park.
The RV furnace is inefficient, noisy and cycles on and off with heat and cold.
The propane heaters give a constant warm heat. They are awesome!
They are used by many, many full-timers.
