Out here in Quartzsite AZ and had to fire up the furnace for the 1st time. I want to install an extend-a-stay type connection so I can use a larger tank but DON'T want to use the furnaces due to them ...
Will DEFINITELY keep a window cracked as well as a roof vent. As you all know these rigs are not air tight. We have a full wall slide as well as propane leak detector as well as a smoke detector AND a carbon monoxide detector that are tested on a regular basis. Also the ventless propane heaters sold these days MUST have oxygen depletion sensors.
