ken burke wrote:
I don't understand why you can't use co-pilot because of your height.
The standard Co-Pilot App will only warn of bridges/ etc which are lower than 13.0 ft.
If the person needs warnings for 13 ft 6 inches or lower - the standard Co-Pilot App will route then under too low bridges.
I would assume that RV folks would prefer the Co-Pilot Truck app which allows custom vehicle dimensions - up to 13'6" height, 53 ft length, 120" width and 132,000 lbs weight.
You can also set HazMat categories - such as Propane - to avoid restricted bridges/ tunnels.
Those are the same type things which RV specific GPS units can do.
Which is why we recommend an RV or Truck specialized GPS, and the same applies to Co-Pilot - though Co-Pilot Truck costs $150.
Yes, the standard $15 Co-Pilot does have an RV mode - but it is for smaller RVs, not tall 5th wheels, class A DP, etc.
