SuperDuty5’er, everything I have is in the pass-thru storage compartment; nothing is exposed to the road or outside. My cables and valves are in the storage compartment and I have to open the outside storage compartment door to dump my tanks.
I’m thinking about doing the installment replacements myself because I have the time to do it and it is a good way to get to better know my 5th wheel. The only thing is I have not made up my mind. I went under there and looked at it and I may only need to replace the cables X3 because the valves look fine. Although if I get the electric valves then I would replace everything and install the wiring for the control switches as well.
The more I look at this the simpler it seems and the more I feel like I should cancel my Camping World appointment and just install whatever I decide on myself. I’ve found some stuff online, including pictures, on how to install a new holding tank valve. Nonetheless, thank you for your input.
