avan
May 03, 2016Explorer
Heat pumps have zero to do with air condition air other than there is a heat strip (think "like a toaster" heat strip) which uses the AC fan to blow the limited heat it produces into the rig. As said, it is not terribly effective in real cold weather because of the limited amps. Its advantage is if you have a chill in the air and are in an RV park using non metered electricity. Then you can use the heat pump to warm the rig up using the park's electricity rather than your own propane via you more efficient (in terms of dealing with colder temps) furnace. Where I live we never have cold temps, just cold chills once in awhile, and my condo does not have a furnace, just a heat pump. When traveling and in an electricity furnished cg, I can't remember the last time I've used my propane furnace - just the heat pump and, if needed, I might pull out the electric blanket. When bookdocking, I'll use the heat pump if the genny is running otherwise the furnace.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
