stickdog
May 03, 2016Explorer
janegowest wrote:
Are these considered OK? It's a Carriage Cameo, so I thought it would be a 4-season coach.....
Walls = 8
Ceiling = 16
Floor = 24
Equivalent to 1960's insulation but par for a RV.
As for the heat pump even in the warm humid south there are chilly nights where a little heat in nice. So if your in deep south Florida you may never need it but if your in north Florida you will most likely put it to use.
We have one in our 5th wheel and use it as needed. As others have stated below 40 degrees it may not produce much heat, but if your not paying a separate electric bill at the park you in you might as well use it till it stops providing heat before relying on the propane furnace which you will be paying for.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
