janegowest
May 06, 2016Explorer
RVcrazy wrote:
First of all, Cameo is a good brand...if in good condition. We use our heat pump most of the time. We switch to propane on nights when it is forecast to be below 45, even though some push it to 40. We don't like needing to mess with propane any more than we need to. Only the propane furnace will keep the warm air circulating in your water storage area. Our Hitchhiker furnace will automatically switch from heat pump to propane when the heat pump can't keep up if the propane is turned on (4 degree drop). I don't know if Cameo's works that way.
I believe it does. Why do you not like "needing to mess with the propane?"
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
