janegowestExplorerMay 03, 2016How to know if a unit has heat pumpI am looking at a used unit, whose manufacturer has gone out of biz. The brochure mentions the heat pump as an option, but can't tell if this particular unit has one or not. Salesman says it says,...Show More
LantleyNomadMay 07, 2016You know the unit has a heat pump when the heat is turned on and appears to be running but it's still cold inside the RV.
Related ContentNo Central HeatingDominic air/heatingAddning heat strips to heat pump AC unitsDisable Dometic Heat pump on AC unit? (for dry camping)Motorhome AC Unit not working
