AngelaMandfamil
Sep 01, 2019Explorer
Needing advice for black tank issue
For background: I recently bought a 31ft 5th wheel to live in full time on family property due to the high economical cost of living in my area. The problem I am having is that the people I bought the RV from never emptied the black tank and it went through a few winters of freezing and was pretty full when I got it. I emptied what I could but there is a major clog in the tank, AFTER the bottom bend from the toliet into the tank itself. I have tried numerous things to dislodge this from wands, snakes, chemicals, but nothing has been effective. To make matters worse, the property is not set up for rv dumping, and my current system is to empty into a buddy tank, and then plumbing services will come out and pump out of that. It works well when the system is not clogged. However, because its not hooked up to a sewer system, I cannot keep the tank open and send a high pressure hose through the "back door" so to speak, and have to go through the toilet itself. I am at a loss and my next step is to have a mobile RV come out and drop the tank and then manually fix the problem.
I have been considering, due to the situation where I have the trailer parked, changing out this system after getting it fixed and installing either a composting toilet or cassette toilet. We also have a harsh winter at times and this would also fix the potential issue of freezing the black tank. I do not plan on touring the country in my RV at this time, and I plan to keep it parked, as I work full time, so I really dont want to have to move the trailer monthly to have to go dump at the RV dump site. I have the ability to dump into a port a potty we have on the property on a daily basis if need be, but would prefer not to have to do this more often than weekly.
My question to those of you who are knowledgeable in this area, what are your recommendations? Should I just get the black tank fixed and hope to never have this issue again? or change the system up. Also, if you advise to change the system up, what sort of toilet would be best for my situation. I am the only person in the RV, so one adult user.
I appreciate any response, as I am new to the full time RV world, never encountered an issue such as this with a black tank, and am unsure which direction to go. thank you so much for reading.
