We are new to RVing and bought a 77 Citation camper. When we hook up the hose to the water it leaks out the top. There is a spot to hookup the hose under, a pressure gage on it, a bigger spot on top, ...
I had an old dodge banner mh the silver cap needs a gasket that is gravity fill but you need a plug for water fitting on bottom the air fitting is where you add pressure to system to supply water inside you have an old pressure water system
