Instead of pulling fuses/flipping CB off just reduce the amount of energy being used.
Unless something is ON it is not using electricity...except for those items that are 'hot' when off. And that energy consumption is minimal.
When you stated you tripped 'the breaker' .... was that the CG power pedestal breaker? A 30A breaker?
2800W accounts for 2 space heaters going full blast but what else was ON?
Lights, TV, water heater/fridge on electric of propane?
Converter/charger maintaining battery voltage.
A/C Unit uses NO AC power unless it is ON......flipping 120V AC CB OFF would NOT lower energy usage
Sounds more like power pedestal CB was being overloaded....you had more then 2800W and/or power pedestal CB is weak (tripping early)
