- DianneOKExplorerModerator note...there have been enough personal attacks on this topic. I am closing it due to the amount of caca rolling around.
- Big_KatunaExplorer II
wildwest450 wrote:
Big Katuna wrote:
To expand on why I said its a waste; I Googled some studies some Universities did on septic tank care. They said a septic tank has so much active microbes in it that when fresh feces enters the tank, the microbes it it die because everything has been consumed. What eventually damages the leech field is build up of fiber and certain fats that don't decay, mostly from synthetic fabrics from the laundry. That's why you should have it pumped every five years or so.
Highly doubtful, why is my tank 15 years old and never been pumped? A properly installed and used septic system should never have to be pumped.
This does not take into account kids toys and bees nests.
It takes longer than that. Rid X does not dissolve non-soluables. When those start filling up your drain field get out your wallet. Don't believe me.
www.soil.ncsu.edu/.../AG-439-13/ - Bionic_ManExplorer
Bumpyroad wrote:
Bionic Man wrote:
I for one have used it in my tank. I had the dreaded tower of poo. Filled the tank 1/2 full of water, drove over 100 miles through the mountains, let it sit a week, went to dump and still had problems.
Did the same with Rid-X the next week and my problem was gone. Some may say it doesn't work, but my experience is different.
so after 2 weeks it was more broken up than after 1 week?
big surprise
bumpy
Curious what makes you such an expert on this topic? Would be interested to hear your credentials.
After one week with water only the toilet would burp every time it was flushed. After a week with Rid-X all problems were resolved. Been that way for two seasons now. - BumpyroadExplorer
big surprise
bumpy - Bionic_ManExplorerI for one have used it in my tank. I had the dreaded tower of poo. Filled the tank 1/2 full of water, drove over 100 miles through the mountains, let it sit a week, went to dump and still had problems.
Did the same with Rid-X the next week and my problem was gone. Some may say it doesn't work, but my experience is different. - BumpyroadExplorer
wildwest450 wrote:
All this septic talk makes me wonder where all the white dog turds went? Haven't seen one since I was a kid.
dang, now I will have to lay awake all night worrying about that situation.
bumpy - wildwest450ExplorerAll this septic talk makes me wonder where all the white dog turds went? Haven't seen one since I was a kid.
- BumpyroadExplorerI believe that my septic tank has been pumped out 2 or possibly three times the last 38 years. never have added RidX or any other magic cure.
bumpy - steelpony5555ExplorerWhen I had a septic system my septic guys (friends of the family), told me to add Rid-x now and then since it helps liquify stuff better....seemed to work for me since I only had the tank cleaned out twice in 25 years..... and the only difference in a septic tank or a black tank is one is cement and one is plastic, one empties over time and one empties when you pull the handle. I do use a little Rid-x when I know my rig is gonna sit for a month or two, also make sure there is water in the tank during that time...
brirene wrote:
I read those same studies when I moved to the country and had a septic system installed. Did just what it said, and used nothing. Tank needed to be pumped every 2_3 years. At that time i started adding rid x, or similar product, monthly, or at least every couple of months. At this point, hasn't needed to be pumped in the last 12-14 years. I'll keep using it, thanks.
Is your diet high in Uranium?
About Full Time RVers
1,589 PostsLatest Activity: Mar 30, 2026
