- ksg5000Explorer III hope your wrong about the weather .... but if I thought it was going to get down to 15 degrees in Portland I would drain everything, blow the lines, and carry a few jugs of water to get me to warmer weather. Just my 02 (just winterized the rig because its' suppose to get in the 20's in Portland).
- BumpyroadExplorer
Artum Snowbird wrote:
I would definitely wait. Use a couple of gallons of bottled water kept inside, and keep your waste water from food and washing to use as flush water mixed 50/50 with antifreeze.
If you dump a gallon of RV antifreeze into the black, then use 50/50 to dump for a couple of days until you get to the mid 20 degree temps, you will just be so much safer and less worrisome.
yep, I'd take a few gallons in containers and head south.
bumpy - Artum_SnowbirdExplorerI would definitely wait. Use a couple of gallons of bottled water kept inside, and keep your waste water from food and washing to use as flush water mixed 50/50 with antifreeze.
If you dump a gallon of RV antifreeze into the black, then use 50/50 to dump for a couple of days until you get to the mid 20 degree temps, you will just be so much safer and less worrisome. - pianotunaNomad IIIIs the water tank in a heated area of the rv? If so, filling will be just fine. If it is NOT or is exposed, I'd wait.
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
