Old-Biscuit
Oct 18, 2015Explorer III
Just because it is new doesn't mean it was installed correctly.
Sounds like installer didn't use teflon tape where needed, use new washer/gaskets in fittings and/or tighten fittings properly.
I would go back and check each fitting/connection
Cold water inlet nipple, cold water line connection/fitting
Hot water outlet nipple, hot water line connection/fitting
Bypass line connection/fittings
Electric element & gasket
T&P Relief Valve
Drain Plug
T&P Relief Valve
Drain Plug
About Full Time RVers
1,589 PostsLatest Activity: Mar 12, 2014
