Jim
Nov 04, 2015Explorer
Kaz wrote:
Unless I'm missing something (very possible), all you need to is to offset the parasitic drain on the batteries, which is normally less than 100mW (mine is only about 50mW), plus the self-discharge (assume it's 5% per month for a lead-acid battery). That assumes everything in the coach is off and the only load is for the CO/propane detector, the clock battery, and things like that. 100mW x 24 hrs/day = 2.4 watt-hours/day. With a 70-amp-hour battery, assume a 5%/month self-discharge rate = 3.5 amp-hours/month, or roughly 40 watts/month, or 1.3 watt-hours per day. The total is around 3.7 watt-hours/day. Even at 50% efficiency, a 10-watt solar panel with an output for a couple hours per day would provide 10 watt-hours/day, which is way more than you need. That's why most commercial solar battery maintainers are all in the range of a few watts and work just fine.
Or, the easiest way is to do like other people suggest and buy something with excess capacity and then you don't have to worry about it.
Skip
I know that in my Class A rig the chassis battery draw is much, much more than 100mW (0.1 Watt). It's more like 12 Watt even with the salesman's switches 'Off'.
The draws are to the dash, which supplies the radio memory, the CO detector, and the propane leak detector. Then the steps, also stay powered. Some newer class A rigs have both a computerized tranni and engine which have memories that are, again, kept powered even with the salesman's switches 'Off'.
I think you have a unique rig if yours only draws 100mW while just sitting.
38,769 PostsLatest Activity: Apr 03, 2026
