- JimExplorerThose 'optional' solar panels on top of many RVs ACs are 8 Watt and I've never heard of them working very well to maintain even small 12V coach or chassis batteries.
I wouldn't get anything less than 50 Watts in the desert areas, and 100 Watts in the northern states. - RoyBExplorer IIIf your battery is disconnected with no load then a very small solar panel will do great...
If it is connected to your truck systems or your trailer system than you have to have enough power to overcome the parasitic drains as well as maintaining the battery...
I have a 9WATT solar panel panel laying in the dash area of my truck and it does not do well keeping the truck start battery topped off. I have too much parastic drain for it...
I leave my trailer system batteries plugged inall the time when parked at home during the season and they PD9260C converter/charger keeps them in good shap. During the winter months I just get my batteries charged up good and then completely disconnect them but leave them sitting in the battery box on the trailer tongue.
They do just fine making it through the winter months here. I do occasionally read their charge state and they usually drop down to around 12.3-4VDC by the end of the winter months.
Roy ken - deandecExplorer
harold1946 wrote:
I would also recommend 100 watts of solar and a dual bank controller. That would maintain both the house and chassis batteries quite easily.
I also have 100 watts of Solar and 440 hour battery bank.
Battery (and linked Chassis Battery) stays full if I switch off the house battery switch.
If I do not use the disconnect switch, the current draws exceed the solar replacement.
This is due, I think, to my storage area providing sun to the panel for only about 6 hours per day. - pianotunaNomad IIIHi,
Bare minimum 15 watts per 100 amp-hours of storage assuming no snow cover.
Better 30 watts per 100 amp-hours. This would actually recharge the bank between trips.
60 watts per 100 amp-hours if you wish to be able to equalize the bank. - 2oldmanExplorer II100 watts if you don't disconnect, much less if you do.
- pconroy328Explorer
calthage wrote:
Class A with 2 12 volt coach batteries. Want to maintain while not in use.
You're talking just a solar float charger, right? Just to keep them fresh during the winter?
From what I read on Amazon this morning, 5-8 watts is working for other people. - harold1946ExplorerI would also recommend 100 watts of solar and a dual bank controller. That would maintain both the house and chassis batteries quite easily.
- LVJ58ExplorerOur coach has 4ea 6v deep cycle batteries and we have a 100w solar panel with controller which more than adequately maintains both coach & chassis batteries.
38,709 PostsLatest Activity: Mar 12, 2025
