steveownby
Jul 23, 2016Explorer
Tinstar wrote:
Just FYI, I've posted this on another "coach specific" forum and may be able to solve my problem from potential answers form them. I haven't crawled under there yet since I spent the day cleaning up my roof top A/C units. I may be able to look tomorrow so does anyone have ideas on what I should be looking for?
On my "new to me" 2002 Monaco Windsor, the 7500 Onan genset is on a slide in the front. I went out to exercise the genset today and thought I would slide it out, just to see what all kind of stuff is in there. I pressed the genset slide button but nothing happened. I know it has worked in the past. I tested it when I bought it and again once after I got it home. I tried the switch both directions. I can hear the motor running but the slide isn't coming out. Is there anything I need to do before the slide extends? I'm still trying to learn the in's and out's of this motorhome and there is a lot more to it as opposed to my '94 Allegro Bus. BTW and just FYI, I was able to exercise the generator. It cranks up and runs like a charm.
If you are parked with your slides out, you might be low on fluid. The HWH reservoir is up in the area below the step well. If you have a small storage bin under a step, if you take the fasteners out & lift out the bin, you will be looking down at the pump and reservoir. Also, you might "snug up" the valves on the side of the pump. There is an in & out valve for each slide function. The out valve for the gen slide might be somewhat open.
Any help or ideas are appreciated.
