Tinstar
Jul 23, 2016Explorer
tropical36 wrote:
Is there a release on it, for manual operation and since you're saying that you can hear the pump running. Hyd. pump should be near by and assuming it has fluid, most likely Dextron III.
Does your passenger side floor work and could be the same pump that is used for it.
I have the pump in the driver's side front bay, but only for the floor and since my genset doesn't slide out. I'd like that, but not sure of potential problems and their history in general.
Yes, the passenger floor moves fine. It is air assisted and not hydraulic,,,,, I think.
I crawled under and checked the fluid in the little pump. It's right beside the genset slide on the curb side. It's full and clean.
