FIRE_UP
May 17, 2018Explorer
skinden wrote:
I have a problem. When I turn the key nothing happens on the dash where all the gauges are. House batteries and the Cranking batteries are fully charged and the switches are in the on position. The alternate switch that helps crank with use of the house batteries does not function. I recently removed a motion sensor that was hardwired into the 12 V system. I guess what I’m looking for is a reset switch or the location of the ignition fuse ....
Let me ask you. By the term "When I turn the key", Are you talking about trying to turn the engine over or, are you just trying to turn on the ignition to activate the gauges? If you're getting gauge activation when you turn the ignition "ON", then that part is fine. But, if you're not getting any engine cranking, then yes, you need to look for a starter relay or set of relays. Different diesel coaches have them in different places.
Scott
