kevphillsaxplayer wrote:
ford truck guy wrote:
As far as the numbers on each, I do not know... IF you wanna see where they run, you can always buy one of these -
***Link Removed***
race and label them yourself
Ok. Took your advice and purchased the meter. The cable marked number two goes back to the back bedroom, the front of the box is the line out for the front television. The cable marked 0 is for the cable hook up so that leaves line one which has to be the antenna but I’m getting a fault on that circuit. I don’t know where that goes through my wall. I’m thinking I might have to snake a line up through there and do a reconnection. Any advice?
kp
You are getting the fault because it is reading the roof antenna amplified HEAD. NORMAL. You have an amplified Roof top antenna. That is the reason for the POS and NEG wires to that box. For the roof top antenna to operate correctly that box sends a power signal to the roof top RV head. ALL your OLD system does is send Coax TV and Campground Cable to each TV. Doug
