rv2go
Mar 31, 2016Explorer II
If the thermostat is set 5 degrees above room temp, the gas furnace will come on until the set temp is reached.
If you only want the heat pump to come on, just set the thermostat at 4 degrees above room temp.
38,763 PostsLatest Activity: Dec 05, 2025
