wolfe10
Mar 05, 2014Explorer
Don,
He may or may not have an exhaust brake. The Cummins ISL could be ordered with EITHER an exhaust brake or (more expensive) compression brake (aka Jake brake).
And, if they suspect an electrical issue, first thing is to wire a voltmeter to the 12 VDC positive wire going to the engine ECM and see if voltage drops out when the problem occurs.
Also, be sure to have engine and computer ground(s) clean and tight.
38,769 PostsLatest Activity: Apr 24, 2002
