jyrostng
Jul 24, 2015Explorer
The wall outlet power in the drawing is called uncontrolled circuits. These only come from the circuit breakers and are not through relays in the Intellitec unit. This means you have power from the cord to the box and through the breaker panel. plug a fan or light into one of the outlets and see if the power you read with the cord plugged in will actually run something.
The generator power goes through the same wires as the cord to the board out of the transfer switch, if it works on the Generator, the problem has to be on the cord somewhere. Check where it connects to the transfer switch.
38,782 PostsLatest Activity: Aug 11, 2021
