dougrainer
Jul 24, 2015Nomad
JAT123 wrote:
Inverter is off and still power to wall outlets.
Cannot switch from 50amp,it does not change when I try
IF you are on 50 amp service, you CANNOT change the amp setting. Are you on 50 amp service? On 50 amp service the amp draw meter will also be blank. It only shows amp draw on Genset and less than 50 amp service. Now, the way your Intellitec "knows/sees" it is on 50 amp service, It "sees" the 2 phase 120 Black and Red power input. Since those 2 leads are out of phase, that is how the Intellitec knows it is on 50 amp service. Now, you indicate you are on 20 amp service, and it shows 50 amp. That IS strange. What type of 20 amp are you on? Home outside receptacle? You can reset the Intellitec system by just disconnecting shore power and turning the battery disconnect OFF for 10 minutes then back on. That will do the same thing as pulling the fuse on the Intellitec module to reset. Doug
I should have mentioned, IF you have done nothing to the Intellitec control board or the breakers in the breaker panel and this problem just came up, the odds are the Intellitec module board is bad.
38,782 PostsLatest Activity: Sep 19, 2026
