- Executive45Explorer IIIFuses should be checked with a meter. I would not suspect a fuse however. My bet is on a bad ground from one of the lights....Dennis
- cavieExplorer
19bigred59 wrote:
I'm taking a shot hope someone can help I've lost all marker and running lights I have headlights and dash lights turn signals and brake lights all work I've checked and rechecked all the fuses and relays multiple times
Thx
How did you check the fuses? Where did you check the fuses? - 19bigred59ExplorerI'll try both those ideas
- MountainAir05Explorer IIOr a ground wire that starts at the first light or last depends on how they wired them.
- LwiddisNomad IIIHave you checked the ground?
- thelazylExplorerI'm not an expert but I did have a similar problem. It turned out one of the lights on the front roof had a water leak.
38,773 PostsLatest Activity: Apr 25, 2026
