klutchdust
Nov 08, 2014Explorer II
jarviswin wrote:
I finally got around to looking a little further into the squeaking noise. All my brackets are tight. It was behind the speaker. I had tightened the self tapping screws prior to my 8k trip. Anyway, the 3 on the psg side were loose again. I put larger self tappers with lock washers and loctite. I may even put 2 more in just because I can.
Thanks for reminding me of these. I will also look in other areas and keep you informed.
Bob
I haven't been able to road test my coach much more than a half mile so IDK if I solved the problem or not. Just finished installing the new
dinette.
38,766 PostsLatest Activity: Jan 10, 2026
