Hikerdogs
Jan 05, 2018Explorer
rk911 wrote:Hikerdogs wrote:
...The sad part is the home heating oil dealers are considering the difference as a "delivery charge". The same thing happened a couple years ago with propane. If you went to the dealer and had a tank filled it was $1.94 a gallon. If you had it delivered to your home it was $3.09 a gallon.
so there shouldn’t be a cost for delivery???
I have no problem with a delivery charge. However the delivery charge in this case was 1/2 of the cost of the product. Charging $1.15 per gallon to deliver a product that sells for $1.94 per gallon is a bit excessive
