eric99
Mar 12, 2015Explorer
moisheh wrote:
Are you sure that unit is a Sportscoach Elite? Is it a raised rail chassis? Just bolting up a 10,000 hitch to a MH does not make it a 10,000 lb. hitch. Maybe they reinforced the rear frame section for the heavier hitch. Our Dynast has a 10,000 lb. hitch and it is one beefy "mother". Our Bounder also had a 10,000 hitch and it was beefy. I think it was held to the frame with Huck bolts. You will need a good fabrication shop to install any hitch.
Moisheh
Moisheh,
Elite is written on the side of the motorhome.
If Freightliner says it left their factory with a 10k receiver for a hitch then I have to assume it's an Elite and that the chasis will handle 10k lbs.
I'm told it is on a raised rail chasis but I'd need to double check.
Eric
