- BiggyninerExplorer
msmith1199 wrote:
So you can't fix stupid so lets just let people keep running into the bridge? Clearly there is more of a problem than dumb drivers here. How many times can that bridge be run into before the bridge itself becomes severely damaged? Like in the above photo at Walmart I've seen these types of barriers as well as sacrificial type barriers that make a lot of noise when you hit them. Lots better to hit a break away barrier than hit the bridge.
There is actually a crash bar installed before the bridge to protect it. You can see it on the photo at this website: http://11foot8.com/about/ - BiggyninerExplorerGood compilation video if anyone has 5 minutes to kill:
http://www.youtube.com/watch?v=SxKpLnE3sGo&feature=youtu.be - msmith1199Explorer IISo you can't fix stupid so lets just let people keep running into the bridge? Clearly there is more of a problem than dumb drivers here. How many times can that bridge be run into before the bridge itself becomes severely damaged? Like in the above photo at Walmart I've seen these types of barriers as well as sacrificial type barriers that make a lot of noise when you hit them. Lots better to hit a break away barrier than hit the bridge.
- Francesca_KnowlExplorer
Bumpyroad wrote:
RVUSA wrote:
Bumpyroad wrote:
do what the railroads did before a tunnel, just drop some chains down that are at the same height. smack a chain, you stop. no big expense, cheap and easy.
bumpy
http://rvtravel.com/blog/rvnow/uploaded_images/P1090231-767497.jpg
just referred me to a walmart thread??
bumpy
That link is to a picture of a Walmart barrier... looks like it has dangling warning thingie-dingies hangin' from it, sorta like the chains you mentioned..
- BumpyroadExplorer
RVUSA wrote:
bumpy
bumpy - RVUSAExplorer
bumpy
http://rvtravel.com/blog/rvnow/uploaded_images/P1090231-767497.jpg - BumpyroadExplorerdo what the railroads did before a tunnel, just drop some chains down that are at the same height. smack a chain, you stop. no big expense, cheap and easy.
bumpy - Mr_Mark1Explorer
moisheh wrote:
In our city there is a similar underpass. There are height sensors and a bunch of flashing lights go off. And this is not on a truck route. In the videos you noticed that semis, buses and delivery trucks all use that route. First there should be signs indicating that no trucks can use this route. Then height sensors and flashing lights well before the bridge should be installed. Of course there will still be fools that hit the bridge but not as many.
Moisheh
You are SO right, there should be more sensors or the road lowered or a sign stating 'NO TRUCKS'. So many of the vehicles appeared to be rentals. Expensive mistake.
MM. - ArchHoaglandExplorerYou don't have to raise the bridge...You can lower the road surface.
- moishehExplorerIn our city there is a similar underpass. There are height sensors and a bunch of flashing lights go off. And this is not on a truck route. In the videos you noticed that semis, buses and delivery trucks all use that route. First there should be signs indicating that no trucks can use this route. Then height sensors and flashing lights well before the bridge should be installed. Of course there will still be fools that hit the bridge but not as many.
Moisheh
38,766 PostsLatest Activity: Jan 10, 2026
