pianotuna
Nov 12, 2014Nomad III
Hi,
You could replace the cold air return grill with a 12 volt fan which may push air through the duct work.
I use 120 volt window fans to do that. I have mine thermostatically controlled. It draw a scant 15 watts so it can be run on a relatively tiny inverter.
If you don't exceed 15 amps, it would be possible to use a 120 volt baseboard heater thermostat on 12 volts.
Entirelynutz wrote:
I do have a furnace vent but I don't always use it. I'd like to have an alternative heat source.
38,769 PostsLatest Activity: Jul 09, 2020
