EntirelynutzExplorerNov 12, 201412 volt basement heaterDoes anyone know where to get a reliable thermostat controlled 12volt heater that I can put in my freshwater basement?
pianotunaNomad IIINov 12, 2014Hi,If I were the OP, I'd put a TC-3 in the wet bay and run it back to a 120 volt window fan which replaces the cold air return. I'd run it on a 50 watt inverter.This is similar to the fan I use. Mine draws 15 watts.
Related Content12 volt only refrigerator12 Volt Power IssueNo 12 Volt without converterAtwood water heater problembasement heater
