wa8yxm
Jan 29, 2020Explorer III
I like using a test light to check fuses. Get it at any Auto store or department Looks like an old fashion ice pick with a light in the clear or nearly so handle and a wire coming out...
First clip the wire on a good ground (IE Under the hook I often pick the brake lines) now touch the tip to a KNOWN good 12 volt (The big bolts/screws at the bottom of the BCC the one marked MAIN) bright light. GOOD
Now touch the metal tab inside the small window on the top of the fuse. both of them
LIGHT LIGHT Good
DARK DARK no test but in the specific it's not that fuse anyway
Light dark or Dark light DING DING DING you found it.
LIGHT LIGHT Good
38,774 PostsLatest Activity: Apr 26, 2026
