enblethen
Oct 24, 2020Nomad
Converter is not working.
Check for 120 volts AC to rig. Check to see if microwave or A/C works. Use a 120 volt appliance to check receptacles. Verify circuit breakers are set. Turn off all circuit breakers applying light pressure toward off. Then turn on main circuit breaker if equipped followed by branch breakers.
Verify that GFCI receptacles are not tripped.
