cavie
Oct 25, 2020Explorer
enblethen wrote:
Sounds like you have a fifty amp shore power and the main leg is not working. Are you using an adapter?
Start the genset if equipped and see if everything works.
Master Electrician here. Please tell me how you determined this to be a 50 amp rig? 50 amp RV power is 240 volts. It is made up of TWO main legs each being 120 volts. 240 between the two. 30 amp RV power is 120 volts. One main leg.
