CharlesinGA
Oct 29, 2020Explorer
On the 12v fuse board with the converter, if you have that setup, are two larger fuses, probably green color 40 amp? that are the fuses that blow if you try to connect the batteries backwards. I suspect there are other reasons for them to blow also, but worth checking those two in particular. When these blow, the converter will not charge the batteries.
Charles
Charles
