tenbear
Apr 15, 2014Explorer
Harvey51 wrote:I am not able to run the water pump and the furnace will not run. I do have interior lights,
Lights work means 12 V system is working. That rules out batteries and converter problems. It just leaves fuses, doesn't it? Best to use a meter, ground the black lead and use the red to see if there is Voltage on the outgoing side of each fuse.
Do your lights dim when you try to run the water pump or the furnace?
38,783 PostsLatest Activity: Sep 21, 2026
