jurob
Jul 09, 2015Explorer
It is not 1 particular light.
I will check house battery voltage plugged and unplugged and let you know. I did check the coach battery and I know that has a charge plugged in, but I will check that also. I do have a solar panel or 2, but I'm pretty sure that disconnects when plugged in and not sure how that will effect unplugged and if I can bypass. Connections at the battery are clean and tight.
The lights come on without issue and appear bright and steady.
I appreciate the ideas and will let you know what I find out.
