enblethen
Jul 10, 2015Nomad
What is the make and model of the AC unit?
What is make and model of the thermostat?
Have you checked the voltage level of the converter output? What is make and model of the converter?
How old is your battery?
Power distribution is normally inside the coach behind a panel about 12 inches square. Quite often under the refer. The 120 volt circuit breakers are similar to those in your house. The 12 volt DC fuses are behind a small metal plate adjacent to the 120 volt circuit breakers.
