RN Enigma wrote:
Tinstar wrote:
You need to address if the 12 volt disconnect switch is turned on and working. We're kinda stuck until that is answered.
Husband doesn't see switch for 12 v. Could anyone tell us where that might be located, It's a 2008 Beaver Patriot Thunder.
It is usually just a toggle switch located by the front door. On my Monaco it is on the panel just to the right of the passenger chair. The switch faces the front of the coach. It can easily get bumped by an elbow or your butt on the way into the m/h.
I'll go out and take a picture of mine. Yours will likely look similar. I'll post the picture here in just a bit.
