Happened to me back in 2006 (RV is a 2005) I will tell you 2 "Cheap old man" fixes the first is how I should have done it but.. Well I never do the easy fix :)
Identify the fuse.. in an INTELLETEC Battery control center this will be 5 amps. but there are several and I'm not sure which. Make sure fuse is good and pull it.
NOw cycle the switch. On/OFF/ON/OFF or if it's a three position Both USE and Store positions.. oike 50-100 times. Restore fuse and see if you got lucky
How I did it: Removed switch had a "Devil" of a time re-connecting it. blew fuse. but .. IT WORKED and still does.
Next level of testing
The switch has 4 wires. one pair should show POWER and Ground (You will read battey voltage The other two will NOT.. but you should measure a resistance between them LIkely around 10 Ohms..
THe two wires that measure power: The fuse's load side and ground
The two that measure 10 ohms (or about) The solenoid magnet.
