YC_1
Aug 28, 2020Nomad
Looks like a Monaco??
If you are having to reset the switch near the entry then your cutoff solenoid may be failing.
The solenoid is most likely below the driver in the outside compartment and inside a large black plastic box. Bottom left corner. It is a latching relay and a common problem. Replace the solenoid or just stack all the wires from one side of the large connections to the other for either a temporary or permanent fix. Many just bypass it and forget it.
check these threads
check these threads
38,779 PostsLatest Activity: Jun 16, 2026
