time2roll
Feb 20, 2015Nomad
That sounds possible.... but your 12v should still work fine off battery when the surge protector cuts power.
The battery switch is on, yes? Battery terminal voltage should be about 13.6 volts. The indicator in the RV is probably reading the fuse panel voltage not necessarily the battery itself.
