Dog_Trainer
Nov 16, 2017Explorer
nancyjerry wrote:
Went into a recommended shop to start the conversation of remodeling our Monaco Dynasty 2001. Just ballpark talk right now.
Said the flooring front to back (40') with 2 slides is in $12-15, 000 range because slides have to come out!?
Wow, that was quite the shock, I guess flooring isn't in the picture!
So 4 slide folks look at $20,000?
Anyone done this?
I would ask for a written scope of work. This might give you some idea as to why slides need to be removed etc... I have replaced tile flooring in a 3 slide TT 35" OAL at no where near that cost. What type of flooring are you asking to have put in ? there are some high end flooring today that would be quite expensive. If you are changing floor material be careful to stay within weight limits as a heavier floor will definately affect your CCC.
\I also wonder if your slide is deployed whether you can flip up the carpet that extends from the slide area and see how the current flooring is attached. Seems like alot but as they say sometimes the Devil is in the details.
38,778 PostsLatest Activity: Jun 06, 2026
