Mr_Mark1
Nov 17, 2017Explorer
Bill.Satellite wrote:
Your Dynasty likely had VERY expensive flooring when it left the factory so if it was your desire to replace the flooring with the same type of flooring I believe that you got a reasonable offer. That is some really expensive flooring (likely polished Granite or Marble) but not ceramic tile.
If you are not stuck with this same flooring, Ernie could remove all of this and install high quality engineered wood flooring for somewhere in the $3,000-$5,000 range. His work is top notch but requires an appointment many months out. He's that good!
Their Dynasty is a 2001. They didn't put expensive flooring in those. We had our 2008 Dynasty built in 2007 and our expensive flooring was ceramic tile which was the 'new rage' then. Carpet was the normal installation.
Maybe the Monaco Signature or Executive would have offered a more expensive flooring in 2001.
Safe travels.
MM.
38,778 PostsLatest Activity: Jun 06, 2026
