rrupert
Jun 29, 2017Explorer
If you plug into shore power you should see a voltage jump at the battery, if not, the converter isn't working. Then check to see if there is power to the converter. Check for a tripped breaker and also check to see if the fuse from the converter to the battery is good. Test it, not just look at it.
