rrupert
Jun 30, 2017Explorer
mmoore43 wrote:
How do I find that fuse between the converter and batteries?
Converters should have a fuse or fuses that are either located on their fuse panel or in their rear that are for protection against over current or reverse polarity hookups. There could also be a fuse, but more likely a breaker, near where the wire from the converter hooks to the battery. No two RV's have these things located in the same place. If you have manuals for the converter and the RV there should be some form of diagram that shows these things.
