Sam_Spade
Jun 30, 2017Explorer
mike brez wrote:
Touch the +&- leads from meter togeather to verify beep before testing
AND even more important, be sure that all the power is removed from both sides of the fuse before you attempt a continuity/ohms test.
It is generally NOT good to be testing for continuity that way on circuits that normally are HOT.
If the circuit is still live and the fuse IS blown, your meter or it's fuse will probably be the next problem.
