I have a light switch that has 2 prongs on the backside, and both have an orange wire to it. How do I determine which is the Hot side and which is the switched side? Or is one Hot and the other Grou...
To avoid the possibility of blowing a fuse should you accidentally touch the hot lead to ground somewhere, personally, I would shut off the power source to the lead you're working with.
